1st thing, be honest with yourself about the usage it will see.
if hp, or towing use, most likely you should:
block:
bake and clean block, pressure check, bore, hone, check crank centerline, deck (square it up). chase all threads to clean them out, new cam bearings and freeze plugs..
crank:
magnaflux, check for straightness, check journals for sizing, turn journals if necessary.
rods:
remove old pistons, mag rods, new rod bolts if necessary (it is for hp use) check and resize both ends, hang new pistons.
this is just for block work...I would guess about 700 or so for these items, many times the bargain kits are not real tight on tolerances, so harder to machine the parts to fit them, talk with your machinist, and he may have a better deal overall than a bargain kit can provide, with extra costs needed for machine work to make them work in your engine.
