So I finally got around to replacing my cracked dash pad. New one is from Dashes Direct, vinyl, I painted it M09 blue.
After a bit of trimming, fitting, trimming, fitting about a hundred times, all is good until I go to install the dash panel. And it will fit and line up on the upper right, but the upper left corner seems to need maybe 1/8 to fit without splaying the bottom out of line.
I wonder if I could maybe heat the vinyl up just a bit and nudge it with flat tool rather than guess with a razor.
