maybe a stupid d60 Q?
87 Blue Beast
York, Pa
im am/ am going to be in the market for bigger axles for my blazer. my question is.. if i were to get a d60 front axle, will my steering arm (that goes with my lift), and everything else swap over from my 6 lug 10 bolt front axle? i dont really know too much about d60's, so anything helps!
No it wont you will need different arms. The steering on a 60 bolts to the kingpins not the knuckle like the 44 and 10 bolt. Do a search on Crossover with a 60 and you will see pics I'm sure.
if your seriously, going to get a d60, wait to do crossover steering. it is much simpler and cheaper then doing it on a d44. for the d44 you have to have the correct knuckle, get it drilled and tapped then buy the arm. for a d60 all you need is the arm for on the d60. the steering box sector shaft will be the same for both. you will need a new pitman arm for both, and a draglink.
