84CUCV said:The auto store by me had 800cca blue top Optima. For 120 each. more then i thought it would be. how are these? desent batteries? Could not find 1000cca. i was thinking the dealership, but i dont think i would have the$$ for that. thx for the help
I don't know your area much but if you go to sears, you will find 1000CCA batteries for less than the optimas.
Not that the optimas are bad but you probably don't need what they offer.
Even a 950 or 900 CCA is better than 650 but DO get 2 same size same age.
If they are different they will drain each other or actually one will drain the other and that will make a weak setup that is not up to the task and it would burn the other battery.
IceMan
