Since this ORD subject seems Hot to night I figured I would lay out my own mistake!!!!!
87 K5 with 4 inch TC springs, Furd shock towers (from ORD) front shackles (from ORD) all leaf spring bushings (from ORD) greaesable bolts (from ORD) shackle flip in rear (DIY4X) and 5100 Bilsteins and 5125 from ORD.
So front shock's I have mounted vertical (can get a degree for you guys) and rear are in stock location bolt to a want to say 78-79 FF 14 bolt. I have hardly any travel in the rear for shocks and when pick it up on a lift the pass side hangs lower and pulls toward that side.
No genius at all like you guy's but what is it going to take to get my truck to ride smooth like it should with Bilsteins? Never got into mesuring etc as this is my first 4x4 truck. I already know I am probably going to have to cut off rear shock mounts on axle and install different ones in different spot on axle.
So Don't think I am bashing ORD as I have bought parts from them and support them. This is a learning curve that needs some knowledge thrown my way!!!!!!!!
