measurment on 14FF center pin to center pin?
ImpalaSS
if anyone can tell me what the measurement is on a 14 FF from center pin to center pin it would be greatly aprecited...
trying to figure out what my axles from! so i need the measurment for a 3/4 14bFF and a 1 ton 14bFF
also if anyone knows the measurment for a 67-72 12 bolt that would be great!
thanks again
68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, dana44, 14 FF, <a target="_blank" href=http://communities.msn.com/68K10>http://communities.msn.com/68K10</a>
I just went out and measured mine and it looks to be 42 1/2
That is on a 3/4 ton 14FF
Middle of the hole to middle of the hole.
<font color=green> Too bad ignorance isn't painful </font color=green>
You can use any 1 ton 14FF on your '69 without doing any relocations of the spring perches. The shock mounts would need to be relocated, though.
I'm not picking my nose...I'm just pointing at my brain!!
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
Good that yours is 42.5, cuz that is what is supposed to be.
If you ain't hurt, you ain't playin' hard enough.
The General
Aren't the '67 to '72 trucks all the narrower perches? Like those on the 1 ton rears? Or are there some years you can use a 3/4 ton wider perch on?
Personally, I have never messed with the '67 to '72 trucks. So, I'm just passing what I have heard.
They are all narrow just like the 1 tons.
See Ya,
Keith
<font color=green>Born to Drive My K5</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
68SWB,
I was just taking a few measurements last night....!
The 12-Bolt that I have under my '72 appears to be 40" (It's hard to get a perfectly straight measurement with the diff in the way....)
The 14BFF sitting in the "on deck circle" measures what appears to be 42.5" like everyone else is saying.....even HARDER to get a straight measurement (bigger pumpkin!)
Good thing I just bought a new die-grinder.....looks like I'll get to practice with it on the 14BFF.....cutting off the spring perches and shock mounts!
-Greg72
'72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
<font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
