Mech clutch linkage problems.
broncoman6524
chuluota Fl
I'm having problems with the pushrod popping off of the clutch fork. The fork is snapped onto the throwout bearing, and has the spring from the pushrod part of the Z-bar to the fork, and the fork to the frame. Going in opposite directions.
The Z-bar can "float" back and forth about a 1/2 inch. I ziptied it towards the frame and I haven't had a problem since. Do I need a new Z-bar or can I put washers on the ends to take up the slack?
I can get a picture this afternoon if it will help.
Thanks, chris
The z-bar on mine has less than a 1/4" of play,(frame to engine). Also, besides the return spring between the fork and z-bar, there is also a return spring going from the fork forward to my engine mount. I did rebuild the z-bar with new bushings from NAPA along with a new ballstud on the motor also from NAPA. My original problem was pulling the z-bar off the ballstud when twisting the truck or heavy gas on the big block, never had a problem after adding the extra return spring to the fork though. Good luck!
