I know this is a standard problem, but I'm still going to ask the question again. As is typical, my rear passenger upper shock mount got wallowed a little and ended up cracking the frame around the hole (looks like a triangle shaped piece could just pop out).
Additionally, the frame is tweaked down a little at that point, so the stud angles down when flush with the hole. What's the best repair option here? The most obvious, I guess, is to weld it all up. Weld the crack, then weld a washer onto the frame. Eliminating the angle would require shimming it somehow, maybe with half a washer on the bottom of the hole.
I have some 2x6x1/4" steel tubing, and I notice that the inside of this tubing is 1.5", the same as normal shock mount width. If I cut it into a C-channel, I could span the hole, and mount or weld the C to the flat part of the frame. It would be sort of imitation double shear that way, and would be pretty tough I think. The trick I haven't figured out is how to get the shock mounting bolt/stud hooked up in the back. I could go all the way through the frame, which might be okay, or maybe I could tack a nut onto the back side if I could get enough space. What do you guys think?
I know I know
