gonefishin
Ok everyone I am about to box my frame on my 89 k5 what thickness metal is everyone using? I am thinking 1/8th I can get enough of that for like $60 to do the whole thing. Does anyone think its not thick enough?
well anything is better than nothing but also don't go thicker than you frame.Ok everyone I am about to box my frame on my 89 k5 what thickness metal is everyone using? I am thinking 1/8th I can get enough of that for like $60 to do the whole thing. Does anyone think its not thick enough?
I have a stupid question. I'm always hearing about people boxing their frame. The profile is a rectangle which isn't the strongest shape. Why not make the profile a triangle, the strongest shape. Basically weld the plate from the upper inside corner of the frame to the lower outside edge. I'm sure there's a reason but my brain's not working right now.
Remember most that posted did 1 ton frames which are thicker, his is a blazer and it's pretty much 1/8".Went back and checked pm's. Kert said he was 10g on the frame plates. I would personally still advise 3/16, especially if you are mounting any crossmembers off it. By the looks of those numbers posted all those frames are thicker than 1/8 and most thicker than 3/16.
