easier to bend buy hand then with bender from parts store , from my expierence. i replaced both of mine with straight steel line from the parts store, and used the old lines as templates to bend them and they work great with no more leaks.
x3 on replacing them with brake line. Cheaper then the pre-bent ones. If you don't think you can do it in one piece, start one from the trans and one from the radiator then connect them with a compression fitting.
brake line is either 3/16 or 1/4, you want 5/16 hard line. I know the factory was 5/16 in my 3/4 ton w/ a th400 trans. I used a coat hanger to bend as mockup first because the P.O. butchered the stock lines and i needed something to start with.
