Might score bigtime, 56" spring question...
4x4shortbed
Douglas County, OR
I got a parts truck with 3/4T axles & am about 1/2 way through my swap when I stumbled on another parts truck with a 6" lift. It's a '86 Suburban 3/4T & has a lift kit(I didn't think to ask which brand) that has rear lift springs instead of blocks. My question is do any of you fine CK5er's :bow: know if this truck has 52" or 56" springs & if it does(or if it might) have 56"er's, whats the procedure for swapping to those in my '77 Blazer? I'm quessing I just use the shackle hangars from the Sub?
Thanks- John
Pretty sure 3/4 ton burbs got 56's but that might just be the 2wds, seems kinda random what springs GM put under what, always exceptions. Not sure on the swap to the k5 I know if you have a shackle flip you just swap sides to go from 52's to 56's. Your rear hangers should be the same as the ones on the burb so I guess just moving yours back and drilling new holes would work
Well, the fella had said the Sub had rear springs, but I went over & looked at it in person & it has blocks. Oh well! That makes it easy.
Later- John
