Low87
Registered Member
I've been reading this forum & others trying to get to where I can ask reasonable questions.
I need to replace the motor in my '89 Jimmy. It needs to be reliable moreso than powerful. If I can get mileage in the 15 range I'd be very happy.
As much as I'd like to swap in a vortec, or better yet an LS, that's not going to happen. I need to keep this simple and downtime a minimum. No added problems.
Tempted to drop in a Goodwrench crate, but I read where TBI heads just plain suck. So what I want to do is build a reliable TBI with operational improvements where available.
I want it to work together, and I will change exhaust & gears to improve driveability.
looking at the ported TBI from Marine Performance Parts
http://marine-performance-parts.com/cfmtechportedthrottlebodyforgmtbi435057.aspx
aftermarket heads (no idea)
I'd like roller cam & rockers
short block from ?
stock or Edelbrock manifold, matched to heads
larger battery cables, 8.8mm wires, delco plugs
I have a MSD coil & Pertronix distributor to use.
Fuel pump, sender, filter have all been replaced recently. Can swap filter out if necessary.
No idea what gears would be good. Stock height, may lift up to 4" over the next few years. GM 10 bolts, will likely stay that way. 33x12.5x15 tires.
I'd appreciate some guidance. My lack of engine experience (I've done the swap on my '87, but that was a straight Goodwrench long block swap) is making this a lot to digest.
Budget is still in the works. I've got some other necessary projects to complete with the money coming in, most importantly with the engine is saying bye bye to rust.
short block from ?
