Intakes and valve size...
When selecting an intake, keep in mind that the Vortec head has a taller, raised port location that does not match up well to non-Vortec intakes. If the intake was ported to match the height of the Vortec runner, then it would be so wide that the flow numbers would drastically be reduced. If the Vortec head was 'ported' to match the intake, the mouth would be so wide that you would lose torque in gobs due to the CC increase. You should find at least 10+ hp in the 3500 to 5000 rpm range with just a standard Vortec -based intake that has the correct runner location, not to mention a realistic 15+ ft/lb of torque to be had up to about 4000 rpm.
Vortec combustion chambers do not lend well (from the factory) to larger 2.02 valves due to shrouding of the intake valve at over .200 lift. When we did my Vortec engine, we did a flowbench test between my 1.94 heads and a customer's 2.02 heads and found that they flow similar numbers to about .200, then my heads actually were better to .400...and his started to outflow mine after .550. However, the cam I selected was tapped out at .515 lift (even with the 1.6 rockers) so the 1.94 was beneficial. Once we cleared out some space in the combustion chamber for the 2.02 valve, he picked up approx 15-20 cfm of flow from .300 to .600 lift, so you would want to look into a larger valve only if you budgeted to have the combustion chamber clearance to help unshroud the intake valve and if the engine was to see higher RPM than stock on a regular basis. If this clearance is not done to correctly keep the intended shape of the chamber, quench and flame travel will suffer, negating the benefits of the Vortec head to begin with. Overall, I say it it would not be any advantage in a Blazer/Jimmy engine so I am sticking with the 1.94 Vortecs.
Dos centavos,
MLRTYME
