VA Mild built 350
RSWORDS
GLOUCESTER, VA
350 4 bolt block, bored .060 over vortec heads, eddlebrock performer intake, brand new 750CFM double pumper (quadrajet in the pics), comp xe 262 cam, new HEI, Headers, etc.
Comes with everything from the air cleaner to the headers.
Motor is turn key.... mostly....
Here's the bad. The boss for the starter is broken off so it will need either
-welded back (I have the piece)
-run with manual trans that has provision for starter mount
-adaptor to run 3 bolt starter
Located in Mathews VA Asking $1,500.
