Military Tires Baton Rouge La
k5fd89
Hold my beer..watch this!
Baton Rouge, Louisiana
Military tires 125 for rim and tire for first four, 100 bucks each if you buy 5 or more.
36's on 16.5 various conditions have 11 to choose from.
Contact me here or at 225 241 1945 or [email protected]
Troy
How much for 4 or 5 tires shipped to 45805? Don't need wheels, but will take 4 run flats if you have any.
not sure how to tell if they are run flats. For 4 tires UPS estimate is 565.00 and Old Dominion Freight Line wants 400.00 (cheapest on shipping quote they go up from there and that terminal to terminal) if my weight and height estimates without rims are correct.
Holy shipping. It may be cheaper to ship them ups ground. It was 100 bucks for me to ship 2 28 inch tires on wheels to Oklahoma from Ohio. If you can get a weight on the tires, and I'll assume they are 37x37x14 for dimensions, I'll go in to ups tomorrow or Saturday and see about pre paying shipping if it will be cheaper. Then just send labels to you.
I called my local depot for direct drop off and cost of 37X37X14 with a appox. weight of 50lbs each (assuming the rim weighs the additional 49lbs of the total 99lbs they are) and the quote on a large special tire freight ground was 623.00 for 4.
might want to register on gov liquidators and see if you can find a set closer to you.
Let me know we can set up payment and I will get out the best 4 or 5 I have and start breaking them apart.
hey I can do a pallet and drop off to a depot. I have abf, yrc, Old Dominion Freight close by or can have it ready for a residential pick up too if that helps.
I'll certinally keep it in mind. unfortunately, if I'm going to spend that much (800+) I'll probably end up buying a new set of something. I appreciate the leg work you have done and I will keep it in mind.
