Like title says looking for pics of clean laided out spark plug wires on a TBI motor. I plan on cutting wires down to length and using factory wire separators. Using AC Delco 8 mm premium wires.
I used the rear of the head brackets from GM and ran the wires under the manifolds instead of on top for header clearance with the Thorley Tri-Y's. I used Accel Ceramic boot plug wires and cut them to length.
The brackets on the back of the heads were modified stockers, the sides were modified as well and bolted to the small holes in the cylinder heads between cylinders. I don't know if I have any pics but I will check.
