readymix
3/4 ton status
I am wanting or needing to make a brace for my York.
I want to run a brace from one of the mounting holes on the york back to the middle of the intake on the pass side. There is a bolt nut combo dealy that holds a bracket to the intake. I think that if I run a mini-link type bar between the two points it will prevent the york form vibrating so much when running.
Few questions here:
1. Is it a bad idea to run a brace like that? between the aluminum york and the aluminum intake?
2. How do I best go about building said brace? I was thinking about a small piece of pipe with some nuts welded to the ends. Whatever I connect to the york will be threaded and have a jam nut on it.....make sense at all??
Any suggestions? I could take a few pics to illustrate if it would clarify anything.
Few questions here:
