B
Bohemian
Guest
1982 K5 Blazer with GM 10 bolts front & back.
anybody have experience with mini spools and lunch box lockers?
i can't afford to put one tons, a np205 and a 6" lift in right now...
so i'm thinking about throwing either some lunch box lockers or mini spools in my front & rear gm10 bolts, because they're plug & play and cheap.
I just use the truck for hunting mostly, so i think either will do me until i can put the one tons in.
I don't want to throw a bunch of money in open diff, weak axles like the gm 10 bolts, so if there's not of advantage to lunch box lockers over mini spools I'd like to go with the mini spools cause they're so cheap.
what say you?
thanks in advance.
what say you?
thanks in advance.
