Mini-starter install - help needed
crazedyak
That Guy
The Durned South
While trying to install a new battery/ground cables in my 87 Blazer the battery terminal and ground terminal sheared off the solenoid... so I decided to buy a new mini-starter from Jegs. It arrives all shiny, small, light and with no instructions. I DID download the instructions off Jegs website, but there is no explanation of what is connected where.
Question... What wire goes where? 87 Blazer 350 TBI
Big stud in the first is where the heavy gauge wire from the battery goes, small spade underneath that is for the start switch wire. Those are all you need to worry about, other than bolting it in and turning the key.
