Ok, So I just replaced the cracked flex-plate on my 84 CC. Found out that when the engine was replaced they used the newer style one-piece rear main block from 86 to not sure what year. I got a flex plate for an 86, which was the same as what was on there, and put it all back together. Now my starter is not aligning properly (too far away from ring gear). The starter was already marginal so I decided to replace with a mini starter. My block is set-up for both staggered and inline bolt pattern for the starter. I was looking at summit and saw almost all of their mini-starters are inline bolt pattern even with 168 tooth. Can I use the inline pattern starter as long as its the 168 tooth or does it have to be the staggered? Its a 350/ TH400 combo Any help is welcome.
