okey dokey. see what you want post here, try and keep this somewhat organized for me.
if you need small parts theyre likely free with the big stuff, ill just toss em in the box
round pattern NP205 as pictured - SOLD
1x th400 fig 8 205 adapters - 125 each
2x th400 round 205 adapters - 125, one with the new poly energy susp mount 150
2x fixed yoke rear output shafts - 85 for the second w/o yoke, 125 for the last whole housing thing.
fixed yoke rear seal retainer - 30
10 spline front output with yoke - 30
2x 30 spline front outputs - 30 each
2x 30 spline front flanges - 10 each
front seal retainers - 10 each
long input gear with seal retainer - 125
3x front output rear covers non synchro - 10 each
idler gear cluster - 25
idler shaft with nut and cover and shims - 10
2x shifter boot rings real nice - 15 each
reeeeally nice boot - 25
2x straight up and down shifters real nice chrome - SOLD
7x shiftrail pin things free with shifter related stuff!!
almost all gone
4x rubber plugs still soft - 10
2x shift rail balls and springs - 10
nuts 30 and 32 spline versions - 3 each
4x shifter bolts, one without a zerk - 15 each or free with shifter
5x stock shift rails - 15 each
7x shift rail connectors - 5 each
4x the little connector in between there, two types, - 5 each
speedo gear, driven gear? - 5
bolt on speedo thing (no idea what it does) - 5
5x small bearing snap rings - 3 each
2x front output thick thrust washer deals - 5
4x shaft snap rings - 3
4x shift collars - 5
3x shift forks, 2x roll pins - 10
2x shaft big gears - 10
2x drain plugs - 5 for the pair
pto covers - 5
four little rod things -5
almost all gone4x rubber plugs still soft - 10
pto covers - 5
