xenomarine
I'm missing two parts in particular for my np205. I need a detent spring and the thing that holds it in, and the speedometer worm gear. I think the detent spring is what it's called, it's the thing that puts pressure on the shift rail so it doesn't slip out of gear. I broke one off in the case because I'm the man of steel apparently!
I rarely have time to go to pull a part locally, so I'm seeing if a member has a junk 205 they don't mind tearing into a little for me.
