Misc parts: 4" lift blocks & t-stat housings
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
4" tapered lift blocks for 2.5" wide springs. Just bought these a month ago. Installed them and took them back out because I needed different height blocks. $30 shipped
Angled water neck/thermostat housing. Never used, includes gasket. $10 shipped
Straight up water neck/thermostat housing. Never used. I can include a gasket, but this is also intended to be used with o-ring. $15 shipped
***SOLD*** 1" spacer with 2 NPT ports. This is meant to be installed under a thermostat housing. I have 2 temperature switches installed in it. One is 185°on/170°off and the other 200°on/185°off. Trick is I don't know which is which. The switches are $29ea new from Summit. I'd like SOLD was $30 shipped for the whole thing.
***SOLD***These are Black Widow Performance shackles. 3/8" thick. Holes are 6.25" on center. The black widow is engraved into the steel, my wife hand painted the black. The bolts are rusted to the sleeves in the picture. I need to cut them off unless buyer wants 2 free bolts. SOLD was $10 shipped
***SOLD***1410 yoke for a NP241 SYE kit. I bought this because I thought I had messed up the first yoke I installed. Turned out to be user error so I have this extra one now. New never used. SOLD was $40 shipped.
Okay, the first section is 1.875" diameter and that runs for 0.585". Then it steps up to 2.125" diameter (which I would assume is the sealing surface) and that runs to 1.17" from the end. Then there's a last little bit that is 2.15" diameter that runs to 1.55" from the end.
what the major ID? Trying to decide if I can turn down much. Thanks.
