pontiacratrod
Registered Member
well, after a couple months of screwing around i finally pulled all the emissions crap off my 86 1/2 ton gmc sub. put a mid 70's dizzy and q-jet. replaced exhaust to delete cat etc etc etc. new carb, plugs, wires, cap, rotor and coil. drove it for the first time today and here are my problems.....
if you stand within a mile of this thing you will pass out from the exhaust fumes. i dont see any smoke, but it smells like it is running horribly rich. its got a misfire that keeps a rhythm and is worse at low rpms. looks like blowby or exhaust coming out of heat riser (its not loud like an exhaust leak should be though). if i keep it in overdrive and try to drive it falls flat on its face, rpm drops and it seems like it floods and almost dies. it will only run moderately ok if i keep it in drive. it runs the best if you beat the crap out of it and rev it up. ive got the timing set at about 6 or 7 degrees. any help would be appreciated......
