k51977blazer
So I just bought a 1976 k5 blazer and the guy who had it before me installed a new rear floor but there is no brackets for the rear seat is there anywhere I can buy these
There are no brackets, you just bolt the seat to the floor.So I just bought a 1976 k5 blazer and the guy who had it before me installed a new rear floor but there is no brackets for the rear seat is there anywhere I can buy these
I thought the seat latched in there is two latches in the backThere are no brackets, you just bolt the seat to the floor.
If it has latches in the back, it's a 78 or newer floor and you need the newer fold and tumble seatI thought the seat latched in there is two latches in the back
I am confused.How did the ones before 78 bolt in, the blazer is a1976 and the seat I have is from a 1987
I am confused.
You mentioned latches in the rear is that on your seat?
If so you need the pockets in the floor which is what I thought you had.
I did a simple solution, I cut a slot in the floor and put a round bar under the floor.
The front brackets will bolt to the floor, you just need to offset the hole about 1/2"[/QU
Yup thats it
That's the old style.Yup thats it
I just bought the seat it came from a 1985 blazer, there was no seat in my truck when I bought itThat's the old style.
Your seat is different you said you have latches in the back
The seat I bought has latches in the back of the seat should I try to find a older seat for mineI just bought the seat it came from a 1985 blazer, there was no seat in my truck when I bought it
Ok ThanksYou need a year appropriate seat. Your truck and seat won’t jive unless you want to do some fabrication and cutting. Doing that is probably pointless and more trouble than its worth when it’s far easier to just get a 76 or earlier seat.
I took out my rear seat in my 78’ to put in an 80’s third row suburban seat which wasn’t a plug and play. Needed some tweaking on account of how the arm-rests attach. ( see picture for latches). Seat “rolls” upward on that hook latch to goes into the bed...
My old 78’ rear seat is now my “couch” in the garage.
Get the right year
As I mentioned earlier, if you want the nice feature of fold and tumble, you can do it easily or spend more time and money and do it right and look like factory.The seat I bought has latches in the back of the seat should I try to find a older seat for mine
What materials did you use it’s not a show rig or anything I don’t need it to be perfectAs I mentioned earlier, if you want the nice feature of fold and tumble, you can do it easily or spend more time and money and do it right and look like factory.
I did it easy.
It cost $5
And it took 30 minutes
I cut slots in my floor and put a round bar on the bottom of the floor secured with straps.What materials did you use it’s not a show rig or anything I don’t need it to be perfect
