missing snap ring on front wheel bearings
SwampLife
Registered Member
Moultrie, GA
Changing my front wheel bearings today, and found that the PO left the snap ring and washer off. also the locknut was literally finger-tight, like i never touched a wrench to either nut to get them off. Anyway i got it all back together and torqued down to specs. how important is that snap ring and washer? i would feel alot better with them on there, but i have no idea of the size i need. If any of yall happen to have a hub taken apart right now i could really use a measurement of the ring and washer.
here's a pic i found on another forum of the snap ring im talking about:
Its not absolutly needed I have run without one.
What it will do is allow the shaft to move in and out a little and it can rub the inner c, causing some damage to either the C or the axleshaft.
Should be pretty easy to take the other one and match it up.
I would definitely run it
I ran mine for years without it. I didn't know it needed it. Does let the drive shaft move a lil. Didn't cause any problems though. Any parts store should be able to look it up.
thanks yall, if the other side has the snap ring i will go match it up, if not at least i dont wave to worry about anything falling off
I lean towards the thought that it is an important part of the axle assembly.
IMO - The stub shaft is designed to ride against the back side of the spindle. No pressure against it but it should touch it. That is why it has a large brass or plastic washer on the stub. I think that this is the position that the shaft needs to be in to keep the shafts u-joint properly aligned in the the ball joints axis. I use shims behind that snap ring to hold my stub shaft snug against the back of the spindle. Since I started doing that I have broken fewer axle shafts at the u-joint. Maybe by chance, but I think there is something to it.
