You'd never know it here!--look under 8 out of 10 GM trucks that were built after 1990's and especially the 2000 + ones,you'll see flaking layers peeling off like delaminating plywood,or holes where shock mounts tore out,the round tubes they use for crossmembers are either very thin to start with,(and are,compared to older trucks!)--or were made from recycled pre-rotted steel...the tabs the shocks mount too whittle away rapidly,if they dont come right off the tubes,before the rest of the frame develops issues often..
I need to get a digital camera so I can show you guys what used trucks look like underneath,that are not even 10 years old yet..some seem to survive quite well,while others look like they sat in battery acid ...
I dont know what the corrosive de-icing chemical choice of the year was recently,they have gone from rock salt to calcium cloride,to some new "green" types of de-icers that are supposedly less corrosive to vehicles and bridges,but trucks still seem to rot away fast around here--I'm sure lack of washes and a "dry" winter with little rain to wash the stuff off has some effect on it also...its weird how some trucks have perfect sheet metal,but the frames crumble away,while others with perfect frames have extensive floor and cab mount & rocker rust issues..
