ace138
What size ubolts do I need, when running stock 52’s leaf springs (4 leaf with stock over loads) with shims? Is it ok to drill out the stock 10bolt Ubolt top plate, to use for the 14bolt ubolts?
ace138 said:What size ubolts do I need, when running stock 52’s leaf springs (4 leaf with stock over loads) with shims? Is it ok to drill out the stock 10bolt Ubolt top plate, to use for the 14bolt ubolts?
Dudge said:http://www.ruffstuffspecialties.com/catalog/u-bolt-58-x-3-38-x-10-p-73.html
RuffStuff sells different size ubolts. As well as plates and complete swap kits.
