more info
thor1982
Registered Member
Iowa
The truck was running a week before i had to replace the fuel filter then it ran great then a few days later the starter went out replaced that it work fine then i started it up took off down the road and it was like some one hit the off switch and it died then i replaced the cap and all that and it also has a gear drive instead of a timing chain which confusing me on the timing being off but i still intend to check it
