HTML:
my pulley is perfectly in line with the crank pulley and its spinning true.
the only thing i can think of is that it just isnt getting tight enough so where is the proper pry point to get my belt tight enough.
when i do tighten the belt its very taut and has the 1/2 inch deflection thing or whatever. then after a trip on the highway it will work its way to flipped over. today on the highway it jumped off the pulley!
i put it back on real tight and by the way home it was already loose and flipped.
i tightened the **** out of my bolts too! its the second Gates belt so whatever that tells you.
short of replacing the belt anyone got any ideas cause im tapped.
