1) Do you guys have insulation under the hood?
A- Is it for fire rating, or sound dampening, both or some other reason?
B- Does it restrict my carburetors breathing?
I am thinking about removing it but I thought I would check you guys first.
2) Drag link question
I recently installed a drop pitman arm, PS pump and gear box. When I drove it straight down the road the steering wheel was at 9:00. I adjusted my drag link in as far as I could and the closest to center I could get was about 10:30.
I thought about grinding the end of the link so I can adjust in more but imagining I would damage the threads I chose not to.
I went wheelin a few weeks ago and was a little rough on it.
Now when I drive straight down the road my steering wheel is at 2:00.
A- Should I just simply adjust the link out until the steering wheel is centered?
B- Is this a symptom of a much bigger problem?
Note- It feels normal when I drive it. I just don't get why the steering wheel went from 10:30 to 2:00 in 1 weekend.
