The radio I ordered isn't anything special and it's just driving some decent 3.5's and 6.5's. No amps or subs. I'm also putting in a cigarette lighter at the same time.
Radio
http://www.crutchfield.com/S-hsmVS23UEQ4/cgi-bin/prodview.asp?i=070XDM6830
3.5's
http://www.crutchfield.com/S-hsmVS23UEQ4/cgi-bin/prodview.asp?i=023GTX352
6.5's
http://www.crutchfield.com/S-hsmVS23UEQ4/cgi-bin/prodview.asp?i=113KFC1661
I'd like to buy some wire for this that can be used to run the two power wires to the fuse box, the speaker wires, the powered antenna, and the cig lighter.
What gauge wire should I use?
Do I need an inline fuse for each of the cig lighter, switched radio power, and continuous radio power wires?
If so, any idea what size they should be?
Lastly, I have several open spots in my fuse box and a diagram that shows me which SHOULD be hot and hot-switched. Yes, I will confirm these with a multimeter. I've had GM specific fuse taps recommended to me and also simply sticking male spade connectors into these open spots. Is one better than the other for this?
Radio
3.5's
6.5's
