Truck is putting me thru hell lately..
Had to plow with my truck yesterday--and to my chagrin,it is still having a loud "bang" or "pop",mostly while backing up in 4wd,but it has done it a few times going forward too..
Truck drives fine in 2wd,no noises,no other issues..
I had replaced two rear tires Sunday so all 4 are equal diameter,I assumed because the tires on it previously were slightly larger in the rear than the front,that was causing a driveline bind up situation..(but last winter I plowed with zero issues with tires that were equally or worse mis-matched ,with no noises or binding at all.)..unfortunately it made zero difference,it still feeling like something "catches" and goes "pow" when it releases,mostly while backing up with the plow raised..
The only things different than last winter,is I replaced the u-joint on the front drive shaft at the diff,it was shot,no needles left in all 4 cups,this past summer.
I just unbolted the shaft at the diff,slid off the sliding yoke,put the new U-joint in it,and slid it back on,and I was careful to make sure it went back exactly as it was,on the same splines,I marked the shaft & yoke before I removed the yoke,and the truck was not moved while it was not connected--so the "phasing" should be correct..
The CV portion of the front shaft had no play,so I assume the u-joints in it and the ball seats are OK...
I also replaced the passenger side axle U-joint,as it also was shot..
You cant really screw that up..
I replaced the drivers side axle U-joint about 2 years ago,its had little use since and is still like new..
The only thing I may have screwed up was the hubs,the first time I put one together,they refused to lock--took them back apart,flipped one of the gears around,then they would lock & unlock properly..this was on the drivers side,and it worked OK all last winter that way..the passenger side I just removed and replaced without letting the parts separate, and was careful to put everything back in the right order..so they "should" be assembled correctly..
One thing I haven't yet checked,is to see if the front drive shaft is hitting anything--the front springs are sagged bad on this truck,they touch the rubber bump stops with the plow raised up,so it might be possible it is rubbing the CV joint yoke against a cross member or something..
The front drive shaft yoke looks to be completely bottomed out on its splines with the plow up too,and even with the plow off,I can hear something feel like it bottoms out when I hit a bump up the road sometimes...so I know the saggy springs might be allowing the shaft to fully collapse at the splines..and maybe trying to bash the front output of the T-case in..
..?..but there are no cracks,leaks or weird noises coming from the t-case in 2wd..
I would think the bump stops would prevent the shaft from collapsing enough to cause damage that way ?..
One thing about the NP-208 though--ever since I've owned this truck (16+ years),is the front drive shaft always has power to it,even in 2WD--so I've had to leave the hubs unlocked in 2WD and I just made sure the front diff was full of lube,and let the axles and u-joints spin..didn't seem to harm anything,but I know it isn't "right" either..I made sure the shift linkage was adjusted right and it was,and it shifts into 4 low and 4 hi no problem,so I think the shift forks and pads are OK..
I'm at a loss how to diagnose this issue--seeing it only seems to do it with the plow on in 4wd,I guess I would have to jack up all 4 wheels and put both diffs on jack stands,with the plow on it and raised,and try running it in reverse in 4wd ,and jump on the plow to see if it makes the drive shaft contact something ?..
Could it be something crapped out in the front diff ?...chain "skipping" in the transfer case ?...seems unlikely to me seeing it plowed OK last winter..
I have a spare NP-208 that is supposedly "good" ,that I picked up cheap years ago,but I'd hate to have that put in if it isn't the problem..seems weird its fine in 2wd and it makes no noises with the front shaft spinning in 2wd,I would think it would be popping or banging in both 2 and 4wd if the front shaft had CV issues ?..
Right now I'm close to vomiting thanks to a miserable cold or maybe the flu,I'm in bad shape and cant be screwing around outside in 20 degree weather--just would like some advice from you guys,if you have any ideas what's causing this..and how to diagnose it..
..?..but there are no cracks,leaks or weird noises coming from the t-case in 2wd..I would think the bump stops would prevent the shaft from collapsing enough to cause damage that way ?..
