vandelay industries
This timing indicator will "lift" the distributor up about .062" from it's normal position.
http://www.speedwaymotors.com/Moroso-26100-Distributor-Timing-Indicator,586.html
Will this affect anything---oiling, wear etc.?
Also, how would you install the screws into the manifold? Drill a slightly smaller hole and then tap?
