An aftermarket ignition won't do much for you on a FI engine. The coil on the other hand will help.
That's what I was thinking too. My tired old 90 Burb could still pull our 32' TT up a grade at 40mph. The engine was lugging real bad, but it would do it. And my engine is stock besides a cold air intake, duals with no cats, and bosch platinum 4's. Just like you I have a 350 with 3.73's and 33's, but my trans is a SM465. So it sounds like you might have other issues going on that gears arent going to fix.
Another thing you might want to consider is slowing down a bit on the freeway. I know, I know, you'd get run over in traffic, but at 80mph, you're trying to smash a brick through a keyhole when it comes to aerodynamics in a Burb. It might take you longer to get where you're going, but if you plan for it, it really isnt an issue. And I bet you'd make your tank go a bit further which could save you $$$ in the long run. Just sayin............
) will help. Need to pull a plug and check their condition, but its only been 30k since i did a full tuneup (Cap, rotor, Plugs, wires, fuel filter, timing), and have definitely replaced the cap/rotor since then, and retimed it.What has your milage been like?
Not bad MPG. An exhaust leak could cause your motor to run rich, thats why I ask. An exhaust leak could pull air into the exhaust system and O2 sensor will read that as a lean condition and cause the BLM's to rise and richen up the mixture - leading to poor MPG.
4.56's and a gear vendors o/d unit then you could have both worlds!!!
I agree with 4x4high on the 383, that and gears would make your truck badass-er
Make up your mind, you can't have your cake and eat it to. Everything is a compromise, gearing is where it's at for torque and torque is what you need for towing. Do you want to pull the Reno/Tahoe grade while towing alot faster than 15 MPH or would you rather cruise down the freeway unloaded doing 80 MPH? Take your pick because you AREN'T going to have both.![]()
Umm I beg to differ im running 3.73's and 37's and I could pull all your turcks in this post at once up a hill at 90 w the ac on and my feet up
and then cruise unloaded 75 mph @ 1600 rpm
Heh but it helps that I make 1109 Ft LBS RWTQ @ 2200 rpm ish
tune it up fix the exhaust leaks cause they are killing your milage by causing a rich condition in closed loop and FFS change the gears.
or umm put a dmax in it![]()
