motor knocking
Littlebubba44
Registered Member
western NY
so my motor just started knocking but allmost never at low rmp's and not high rpm's but just in the mid range rmp's?? so i be worried about rebuild or will it run like that for awhile. and whats a normal rebuild cost generally for a 350? any help would be nice.
srry it's a 87 k10 with a fuel injected 350 (don't know if it's stock, believe that was a change over option?)
thats what i plan on doing but wanted to do a little planning before i went and spent all my $$ one other fun stuff
How many miles are on it?
Does it do it parked or under a load?
Oil pressure still good?
Torque converter bolts tight?
A few things will start making a racket on higher mileage engines.
Timing chain smacking the front cover would be a good starting point.
What's a normal rebuild?
Budget rering & reseal or full on all the way?
Boring a block is generaly $15 - $20 a hole.
Cleaning tanking & inspection prolly $65
Then costs for inspecting the crank & rods, turning the crank (if needed), resizing the rods(if needed) & pressing in the pins.
Since it's at the machine shop anyway get it balanced. Mo $$$$
Chuck the heads in the scrap pile and get a set of vortecs.
Unless by some chance they don't need new valve guides and ya can get by with some lapping compound & a drill.
A generic kit with pistons can be had had for $200 or so.
Personaly for a stock engine I would opt for a crate engine.
What I paid in machine shop fees alone would have almost paid for a run of the mill crate 350 from a local rebuilder.
let the yard noem out, I had to free one the other day at work, them hammers are hell on oil pans.
