motor mount question
dheavychevy38
Algonquin,illinois
I have a 72 k5 that im starting to get going and need to replace a freeze plug on the small block. The one is right behind the motor mount:doah:. Any body have any tips on removeing the mounts ?
There Is 1 bolt that goes through the frame into the mount, 5/8 socket to remove, then the mount bolts to the block with 3 bolts, 9/16s socket to remove them. You will want to jack the motor up as well so that you have room to work
