GsxrMike
Ok guys, I'll try to list as much info as I can. Chevy 350, #8 cylinder is dead. It has spark, it has air & fuel, but doesnt seem to fire at all. That tube on my header never seems to get very hot. I can run my motor for a few minutes and keep my hand on that tube of the header the whole time. Spark plug looks sooty (installed new and rechecked after 5 minutes of run time). I did a compression test last night and it came back 160. I did a poor mans leak down test and pressurized the cylinder with 90 psi with rocker arms removed. The only place its hissing is on the idle air port on the throttle body. Intake valve spring seems fine, not broken, looks just as tall as the others. When I look into the combustion chamber with a flash light it looks very sooty as well. Where should I go from here? I was leaning toward a head gasket issue but I can't make sense out if the results I have. The motor sat for a while so a rusty intake valve and/or seat is the other thing that I was thinking but I'm unsure about that since I have good compression. Header tube isn't clogged because it blows out just fine when I push valve down during leak down test. Seems like it should still fire but isn't. Thanks in advance!
