total timing is measured at full advance and inital timing is what its set to start the motor (no advance)
onetonbb74 said:total timing is measured at full advance and inital timing is what its set to start the motor (no advance)
38377k5 said:A 383 has to be externally balanced. If you have a 383, your harmonic balancer will have a few holes drilled into the surface of it
01maroonz71 said:well...here's an update ya'll....i swapped the fuel filter today(nasty as fug....won't flow worth a damn) and got a K&N 4 1/2in filter today, see what that does...i also filled up with premium and backed the BTDC timing down to 8degrees....and left idle where it was....
heres a pic of hte filter(sorry about picture quality, camera phone blows) but you can see all the brown crap caked on it...what could that be...i also tested the "flow" in the kitchen sink compared to a new one, and it didn't flow worth a damn....
what could that have caused this????? anybody got any clues???
another thing the truck is doing is...it's like the idle changes, sometimes it idles down to about 800RPM in gear after i stop at a light, then if i throw it in N or Park and tap the pedal once or twice it will idle down to about 500RPM(what i have it set at) any ideas about this!!!!
thanks again ya'll.
01maroonz71 said:edit****
also..would going back to a Q-Jet help my mileage and so on?? that may be my best bet. i have had about 5 people aroudn town tellin me to get rid of my holley w/ dual feed fuel lines. they say that's whats giving me 5MPG.
01maroonz71 said:awesome kent, thank you so much for your help.h...i will try to hook up to full manifold vac and see if that helps at all. i geuss i need to get a new timing light so i can check how much advance im getting. since the motor is advancing right off idle, how i change that???? i know that i can change the stops in the dizzy to limit the total advance and i can make it advance faster with diff. sprigs. thanks alot guys!!!!
edit****
im going to try backing the timing down a bit more today and fill up with premium also...im going to try about 4 or 6degrees BTDC and see if it still pings under throttle(like it is now)
01maroonz71 said:Ok, looks like it's a 4150 carb.....but see the flap on the top that's wide open??? on my 87's brand new edelbrock 1406...those stay shut when the trucks not running...are those the seconaries????? thanks again ya'll!
