Motor questions.
Braves dude
Registered Member
Delaware
I have a rebuilt 350 motor with an RV cam and worked heads.
That being said......
1) Does anyone have any recomendations on headers? I dont need anything to flashy, just a nice pair.
2)Any opinions about a throttle body spacer? I understand it doesnt help with horse power but it gives you better throttle response.
3)I hear that a standard fuel pump wont get the job done with a more powerful motor. any suggestions???:1zhelp:
1) Tri-Y header design works great on this application and they typically have better clearance around the spring shackles.
2) May help a bit, but they could create alignment issues with your transmission kickdown cable and fuel lines.
3)Fuel pump should be fine for your application. If anything, an adjustable pressure regulator and guage could help.
I really like my throttle body spacer!
I have an edelbrock performer intake with the throttle body spacer an I have no issues with clearance or cable length issues!! Definitely better throttle response, an better performance for seat of pants feel!! I even got 1 to 2 mpg better cruising mileage on mine!
