Thank you, someone else understands the reasoning besides myself.
I guess you guys are missing the point. You need to consider the "effective length" of the wire. Even if the wire is run to the starter which is all kinds of bad and I'll get to that in a moment.
If your current is water and a hose is your cable. Running a small hose to a bigger hose doesn't accomplish anything. You should have the proper size wire going from the Alternator to battery. On my Truck the wire runs staight from the Alternator to battery and it looks factory. Maybe someone changed it I dont know.
Now the reasons running a wire to your starter is bad is that when the starter kicks in its pretty much a dead short. You have basically shorted your alternator to ground for that brief period of time, limiting the life of your alternator. You could argue that the motor hasn't started yet, but I would argue that for a brief amount of time they are both on at the same time. Secondly its unfused, thats a fire hazzard. Any newer car that wire runs to a fuse box and then to the battery. Thats done for a reason!!!
