MPG drop?
prolinews
Georgia
I'm currently running 33's with 3.73 gears 15-16 mpg , if I went with 35's and 4.10s would there be a drastic drop in mpg or just 1-2 mpg? This is one of those mods I would like to do but been a little nervous since I drive this all over creation and rack up a lot of highway interstate miles.
Goes up about a 100 rpm at 70 mph if I read it right. Not a real drastic difference. Maybe exhaust and a couple other things could keep mpg close.
on what powertrain?
You will lose mpg. I'd bet 3-4 from where you are. Your current figures look pretty high.
700r4 slightly modified tbi 350. The axles in mine are stock but my buddy has a set of 8 lugs under a clapped out suburban that has 4.10 gears and has military 16.5 wheels and 37's that actually look to be in good shape for cheap. I might just buy it and save it for a later on project. I definitely don't want the 16.5s and 37's but they still have Craigslist value lol
With all other things equal in regards to the tire I would suspect it to lose at least some MPG going to a larger size. For example if you went from a 33x12.50 to 35x12.50 of the otherwise exact same tire you are adding weight, rolling resistance, and wind resistance (truck now sits an 1" higher). Regardless of the gears it now takes a little more power to get the truck going and maintain highway speeds.
Now with that said, I don't think it will be major difference again assuming it is an equivalent style tire. If you change the style of the tire it can affect it quite a bit. For example if you go from a 33" all-terrain radial to a 35" bias ply Bogger I would expect a noticeable decrease in MPG, and on the other hand if you go from a 33" Bogger to a 35" AT radial the MPG could get better......but that is a drastic difference in tire styles.
The other big thing to consider when checking MPG's after changing tire and gears is to make sure the speedo and odo are reading correctly.
