Hmmmm billet aluminum trailing arms.....I need to speak to a structual engineer![]()
billet doesn't have to be aluminum
I'm glad to see you will be ditching the hollow dana 44 housing, this rig will finally make sense again.
I'm glad to see you will be ditching the hollow dana 44 housing.
Woah woah you didn't tell me you could make dxf files in cad! Hmmm..
I'm glad to see you will be ditching the hollow dana 44 housing, this rig will finally make sense again.![]()
but there needs to be a rhyme for the reason. Yes its time to fully embrace the 2wd! And yah but billet is one of those words that instantly triggers aluminum. Just because you see way more of it.
Now my mind is ticking 100mph. What type of materials do you think i would have to use if i machined a solid trailing arm. What would the strength vs. Weight br compared to a dom tube with boxed plating be you think?
Im heading into work tonight ill draw a quick drawing of whats in my mind so you can see, but im imagining a width of 2 1/2"s with 1" webbing interlays on each side to cut out as much weight as possible. If the weight vs strength come out to be the same i would probally atempt it. I think for me machining trailing arms would be cheaper amd easier then building tube plated ones.......and just look sickbut there needs to be a rhyme for the reason.
Any other engineers have input on tube/plate trailing arm vs one piece machined trailing arms.
What do the "money no object" race trucks do? It seems like even the richest race teams use fabricated trailing arms.... so that would cause me to question "WHY" they do it. It's certainly not to save money.... they could machine out billet arms in a heartbeat if they wanted to. My suspicion is that it's either too heavy to achieve equivalent strength in billet....or it's more of a serviceability thing (easier to weld in the field during a race if it's damaged).
-G
Dam Nate, this is gonna be cool man.
How bout turbo LS power???
