The distributor was in there since I installed the engine.
The small red wire is hooked to the distributor power wire
The small orange wire is hooked to the B+ terminal
The small black wire is hooked to the C- terminal
The ignition module was removed and the purple and green wire hooked to the magnetic pickup
The white wire is unused
The gray wire is hooked to the RPM input signal wire for the ECM
The big red wire is hooked to a terminal strip fed directly from the battery
The big black wire is hooked to the negative battery cable
I have confirmed battery power and coil power to the box. I even tried to re-install the filter for the ECM RPM signal which was required when not using an ignition box.
In the morning I am going to confirm that I have a good tach signal to the ECM, then I don't know what else to do.![]()
What/where is this gray wire?
