CGT80
Well, I finally checked the timing on my truck again. 406 sbc 10:1, Scat 9000 crank and rods, trw hyper flat top pistons set to 0.005" out of the hole, capped with ported and flow benched aluminum heads, and intake, with a comp cams 270 magnum hydraulic flat tappet (224/224 @ 50).
I am running the MSD 8365 pro billet HEI. It is a copy of the original HEI. I replaced the weight set and springs when I built this engine. MSD tech gave the part number for the springs. The instructions for that weight set says not to use it with the 8365.
I think I am running the silver bushing, heavy silver spring, and a light blue spring. This should give me 25 degrees of mechanical advance all in at 3250 rpm.
This is what I got this morning:
11.5 initial advance
18.5 mechanical advance (without vac can hooked up)
30 degrees of total advance
The big problem is that all the advance is in by 2200 rpm. Both the springs and bushing don't match MSD's charts for what they should be. The advance is off by 1000 rpm. No wonder I had pinging when hauling my 9,000 pound toy hauler (truck weighs about 6500 lbs). It also runs warmer than I would like.
When I first dropped in the engine, I had a faster advance. When the weather warmed up I had some pinging while running without a trailer and the temps seemed high. I slowed it down and saw a big drop in temps, and got rid of the pinging for the most part. I also run an in cab timing retard knob. I don't let the engine ping.
I am going to try the heaviest springs next. I am already at the second to the slowest curve. I think the weights are not correct for this dizzy. If they are too heavy, they would advance faster than what MSD shows in their chart. I can't seem to find a set of stock HEI weights for a 79 chevy.
A few knowledgeable people have told me to set the advance to be all in by 3000 rpm, and to slow it down if it doesn't like it that quick. I know 2200 isn't going to cut it, especially on an engine that can be pushed to 6,000 rpm (I don't usually push it past 5,000 rpm).
I run an adjustable vac advance, and will tune that more after I get my centrifugal set right. I had to set the can to allow advance only at vacuum levels higher than 6 inches, since the engine pulls 5" of vacuum at 5500 rpm at WOT due to the small 600 cfm carb. I may try my 895 Q jet that I ran on the previous engine.
Well, this helped me to organize my thoughts. I just wanted to share my experience and also ask if anyone else has run into the same problem with the springs being so far off from what the manufacture lists them at.
PS. The MSD 8365 is kind of a bastard dizzy. It doesn't use all same parts as the non-smog legal distributors from MSD. I found that I had to use a stock HEI pickup when mine went out, the one from MSD that says it works on ALL MSD distributors, did not even come close to matching what I had. I don't think the tech. I talked to realized this when he told me what weights to run. I have talked to MSD twice, but didn't get anywhere with them.
For the visual people (sorry I don't have a better photo as I was focused on getting it in the truck):
Third time is a charm. Thanks for your help Phill.
