MSD Off-road ignition
Model 6470
Can't use it with my new setup
$100 shipped
Verbage from Summit:
Brand:MSD Ignition
Manufacturer's Part Number:6470
Part Type:Ignition Boxes
Product Line:MSD 6 Off-Road CD Ignitions
Summit Racing Part Number:MSD-6470
UPC:085132064700
Ignition Box Output:Capacitive discharge
Circuitry:Analog
Rev Limiter:No
Timing Retard:None
Data Acquisition:No
CD Voltage Output to Coil:460-480 V
Current Draw:1 amp per 1,000 rpm
Spark Output (millijoules):115 Millijoules
Minimum Operating Voltage:10 V
Maximum Operating Voltage:18 V
Length (in):8.000 in.
Height (in):2.250 in.
Width (in):3.500 in.
Ignition Box Color:Black
Coil Included:No
Warranty:1-year
Quantity:Sold individually.
CARB EO Number:D-40-26 (pdf)
To see a list of qualifying vehicles, enter CARB EO NumberD-40-26
Emissions:California EO Approved
Description: Overall performance and reliability are requirements when you're creeping over rocks, jumping through the dunes, or anywhere else off the beaten path. The MSD 6 Off-Road ignitions' capacitive discharge design produces multiple sparks from idle to 3,000 rpm. This ensures that complete combustion occurs just after your piston passes top dead center, giving you the maximum available power. They feature a special connector that plugs directly into an external rev limiter for easy upgradeability. The 6 Off-Road ignitions' circuitry is encapsulated with an epoxy coating, creating a water and vibration-proof ignition fit for the great outdoors. Weathertight connectors are included for positive locking, water-resistant electrical connections. These ignitions work with virtually any vehicle using a 12 V electrical system and a distributor. They work with points, amplifiers, or magnetic pickups on 4, 6, or 8-cylinder engines.
Model 6470
$100 shipped
Brand:MSD Ignition
UPC:085132064700
Circuitry:Analog
Rev Limiter:No
Timing Retard:None
Data Acquisition:No
Coil Included:No
Warranty:1-year
