MSD, Taylor Wires, MR. GASKET, RPC PULLEYS, ENGINE WORKS & Many more - CLEARANCE SALE
ENGINE WORKS PERFORMANCE www.engine-worksperformance.com
1RTR – Ready to Run Dist. W/ Vacuum Assist - $210
10010 - Pro Billet Timing Chain Set SB Chevy & V6 - $85
10030 - Pro Billet Timing Chain Set BB Chevy - $105
100302 - Billet Timing Pointer SB Ford 302-351 Adj to Damper Size $55
100356 - Billet Timing Pointer SB Chevy 6-1/4 in Damper $29
100357 - Billet Timing Pointer SB Chevy 7-1/4 in Damper $29
100457 - Billet Timing Pointer BB Chevy 7-1/4 in Damper $29
10400 - Stud Girdle Set SB Chevy w/Stock Stud Location $75
10700 - Sportsman Timing Chain Set SB Chevy $29
11100 - Vinyl Carb Cap Assortment $9
11108 - Bowl Screw Gaskets - 10-Pack $8
11113 - Clear Sight Plug Kit $8
11250 - Carburetor Main Jet Extension 2 pack $9
11343-16 - Self Lubricating Valve Seals .343 - 11/32 x .530 $21
11504 - Needle & Seat - .110 in Viton - 2-Pack $11
11535 - Power Valve 3.5 HG Vacuum $8
11545 - Power Valve 4.5 HG Vacuum $8
11575 - Power Valve 7.5 HG Vacuum $8
130010 - Cam Walk Button SB Chevy Aluminum $9
130011 - Cam Walk Button SB Chevy Roller $12
130016 - Cam Walk Button BB Chevy Roller $14
130051 - Bullet Nose Timing Cover Stud Set SB Chevy $18
130280H - Cam & Lifter Kit SB Ford Hydraulic 2000 to 5200 RPM
Good Idle - .460/.460 Lift $110
13400 - Guideplates 5/16 in Flat SB Chevy $20
13401 - Guideplates 5/16 in Stepped SB Chevy $21
135286H - Cam & Lifter Kit SB Chevy Hydraulic 3000 to 6400 RPM
Nasty Idle - .480/.480 Lift $120
135310H - Cam & Lifter Kit SB Chevy Hydraulic 3200 to 6500 RPM
Radical Idle - .488/.508 Lift $120
13600 - One-Wire Alternator 100 amp Chrome $112
145312H - Cam & Lifter Kit BB Chevy Hydraulic 2500 to 6200 RPM
Nasty Idle - .576/.576 Lift $110
15030 – Remote Starter Switch $15
157818 - Claimer Series Pushrod Set 5/16 x 7.800
SB Chevy 262-400 1955-87 - Heat Treated $27
16100 - Distributor Gear - Bronze - .491 in - SB Chevy $32
16101 - Distributor Gear - Bronze - .500 in - SB Chevy
Fits MSD & Some Accel $32
16166 - Billet Aluminum Distributor Hold Down Clamp - Red Anodized $22
16167 - Billet Aluminum Distributor Hold Down Clamp - BLUE Anodized $22
16204 - Fire Boots - Up To 1200 Degrees - 8-Pack – Blue $40
16215 - Ignition Spark Plug Wire Sleeving 25 ft roll – Silver $20
16325 - Header Stainless Wire Tie 7.9 in - 8-Pack $8
16400C - 8.5mm Coil Wire Kit for Points - Red
Silicone with Kevlar Core - Fiberglass braid reinforcement $13
16400H - 8.5mm Coil Wire Kit for HEI - Red
16402 - 8.5mm Ignition Wire Set Univ 90 Boot for HEI & non-HEI Red
Silicone with Kevlar Core - Set of 8 $45
16422 - 8.5mm Ignition Wire Set SB Chevy non-HEI Over Vlv Cvr Red
16425 - 8.5mm Ignition Wire Set BB Chevy HEI Over Vlv Cvr Red
16433BL - 8.5mm Ignition Wire Set Mustang 16V 4.6L 1996-98 Blue
Silicone with Kevlar Core - Set of 8 $55
16580 - Canister Coil Bracket Chrome
Mounts Coils Up To 2.25 in Diameter $10
16644 - MEGAFIRE RPM Pill Kit 4000 to 4800 RPM Module Kit $27
16646 - MEGAFIRE RPM Pill Kit 6000 to 6800 RPM Module Kit $27
16672 - MEGAFIRE RPM Limiter Switch 6000 to 8200 RPM
16750 - Heavy Duty Safety Toggle Switch with Cover
Silver Contacts Capable of 25 Amps at 12 Volts $19
16767 - MEGAFIRE 3-Step RPM Rev Limiter Selector Switch $62
16780 - Remote Battery Jumper Terminals Set of 2 $27
170916 – Timing Cover Seal – SB Chevy $9
17200 - Cylinder Head Fastener Kit SB Chevy 190000 PSI $42
17202 - Cylinder Head Fastener Kit BB Chevy 170000 PSI $42
17506 - Stainless Intake Bolt Set Allen Head SB Chevy $17
17507 - Rocker Arm Studs 3/8 SB Chevy & SB Ford 190000 psi
1.750 in Stud Length $26
17511 - Stainless Steel Hex Engine Fastener Kit BB Chevy w/Hdr Bolts $42
17517 - Rocker Arm Studs 7/16 in SB Chevy & SB Ford 150000 psi
17527 - Rocker Arm Studs 7/16 in SB Chevy & BB Chevy 190000 psi
1.940 in Stud Length $29
20400 - Stud Girdle - BB Chevy - Stock GM Iron & Aluminum - Each
2X Brodix – Edelbrock $170
20700 - Sportsman Timing Set - BB Chevy - Cast - Dual Row Chain
3-Key Crank Gear $29
22200 - Brake Proportioning Valve - 60% reduction
Billet Aluminum - 3/16 in Tube Adapters $52
276510 - Valve Cover Stud Kit - Set of 8 Includes Washers & Nuts $14
31-8 - 12-Point Polylock Set Rocker Arm 3/8 x 1.350 in Length
Rocker slot width .585 inches $21
38012 - Adel Clamps - 1/2 in - 6-Pack $10
38038 - Adel Clamps - 3/8 in - 6-Pack $11
38058 - Adel Clamps - 5/8 in - 6-Pack $12
402000 - Oil Restrictor Kit SB & BB Chevy - Pkg of 2 Includes 2 Spare O-Rings $15
41490 - Stainless Intake Bolt Set 12-Point SB Chevy $17
41630 – Carburetor Stud Kit 1-3/8 in Long $14
41631 - Carburetor Stud Kit 2 1/2 in Long for 1 inch Spacer
Precision machined Bullet Nose $14
41670 - Billet Float Bowl Spacer Kit $55
41699 - Throttle Dual Return Spring Kit Chrome $19
41701 - Street Fuel Filter 5/16”
Glass body allows easy identification of contaminants $14
41720 - Competition Fuel Filter Replacement Element $12
41834 - Mechanical Fuel Pump SB Chevy 285 to 400 CID $55
46500 - Engine Finishing Kit GM 283-327-350-400 w/o Seal Housing
Dowels-Cam Bolts-Woodruff Keys $15
46501 - Engine Finishing Kit GM 350-400 w/Seal Housing
Dowels-Cam Bolts-Woodruff Keys $19
46502 - Engine Finishing Kit BB Chevy
Dowels-Cam Bolts-Woodruff Keys $16
52004 - Fuel Pressure Gauge 0-100 psi Liquid $25
52010 - Fuel Pressure Gauge 0-30 Hg Liquid $25
53104 - Mechanical Oil Temperature Gauge 100-280F Black Face $35
53202 - Mechanical Oil Pressure Gauge 0-100 psi White Face $33
53205 - Electric Voltmeter 8-18V White Face $33
54 - Carburetor Base Mounting Gasket - Holley OPen Center - Each
Also Fits Carter & AFB $6
55 - Carburetor Base Mounting Gasket - Holley 4-Port - Each
Also Fits Carter & AFB 4-Port $6
58B - Carburetor Base Mounting Gasket - Dominator 4-Port – Each $6
58C - Carburetor Base Mounting Gasket - Dominator Open Center $6
60350 - Brass Expansion Plug Set Chevy 350
Plugs for water jacket-cam-oil galley-pipe $21
61350 - Steel Expansion Plug Set Chevy 350
Plugs for water jacket-cam-oil galley-pipe $12
71-8 - 12-Point Polylock Set Rocker Arm 7/16 x 1.350 in Length
73035 – Tire Screw Kit - 35 Grade 8 Self Tapping Screws $19
900-16 - Valve Springs Single w/Damper 1.260 OD .876 ID
SBC Z28 Drop-In - Great for RV & Mild Street $32
ML817H-16 - Hydraulic Lifter Set SB & BB Chevy $67
SRK900 - Spring-Retainer-Lock Kit SB Chevy Hydraulic
7 Degree - 1.250 OD $52
BEFORE YOU CHECK SUMMIT OR JEGS - CHECK OUT OUR LIST OF ITEMS INSTOCK FOR YOUR NEXT BUILD.
THESE ARE SHIPPED PRICES AND IF YOU COMBINE PRODUCTS YOU WILL BE LOOKING EVEN CHEAPER SHIPPED PRICES.
THANK YOU AND IF YOU WANT FAST SHIPPING JUST PAYPAL US @ [email protected] AND JUST LIST THE PART NUMBER SO WE CAN SHIP IT SAME DAY FOR YOU.
THESE ITEMS MUST GO ASAP FOR MORE INVENTORY!!!
THANK YOU!
OK SINCE WE NEED ALL PRODUCTS GONE HERE IS THE DEAL FOR THESE PRODUCTS IN STOCK.
COST + 5% FOR CREDIT CARD AND PAYPAL FEES + WHAT EVER SHIPPING COMES OUT TO!!!!
Shipping will be cheaper than you expect as we have a discounted UPS account or if it is small enough we will use USPS Flat Rate Boxes.
THANKS and just pm us or email or give us a call to find out what the pricing is!
SO don't mind the prices you see because it isn't what you would be paying. Thanks for your support.
