MTS poly gas tank $40 -Sold
bp71k5
3/4 ton status
Knoxville, TN 37922
Sold.
I've got a rear poly (plastic) gas tank from my 71. I used it for a while but switched over to a metal tank. It's about 1 year old and undamaged and works fine.
The filler neck was bent to clear the factory body mounts on a 69-72 so a body lift would not have to be added. The picture shows what was done or I can post more pictures.
This is the link to the tank, it's part number 2042, about half way down the page. http://www.mtscompany.com/chevy-gmc.htm
I can ship or you can pick it up Morgan Hill, CA.
No, sorry.
Sending unit?
Let me check if I have one, but probably not.
Fill neck?
The only fill neck needed is built into the tank and requires a rubber hose to attach it to the truck's filler neck. It's either 2-1/8" or 2-1/4", I can check.
Would you ship.
Yes, it's not very heavy. If you get me a zip code, I can check the cost.
Check out this thread from me on it:
http://coloradok5.com/forums/showthread.php?t=200453&highlight=gas+tank
where were you a year ago when I bought a new one... Bump
