Mufflers / Converters / Headers.. save on our website.
MudFrog
Daleville, Va
Hey guys, I broke down and bought a vendor subscription :D
Anyway, if you have any exhaust questions feel free to ask me. Anyone from CK5 will receive a 10% discount off of anything on my website. If you don't see it on my site let me know and I should be able to get it for ya. Use the discount code "CK5" during the checkout process.
This applies to anything.. Flowmaster, MagnaFlow, Hooker, etc..
BTW.. CK5 is case sensitive, be sure to use caps.
I will be doing a 454 swap in my balzer very soon. Can you help me out with the correct header application for it? It is a '74. Any help is appreciated! :cool:
Also, I will be doing a true dual swap on my '87 burb when I swap in a new engine. Your 3' cats have me VERY interested.
I have a question about the 3" cat that you have marked down. I am going to do a 3" system on my truck sometime and I need a cat. Is the cat a good quality piece that is going to last and get me past moderate emissions standards? If so I will order one and keep it on the shelf till I need it. That is a smokin price. Thanks
Harley
Yep, we have a smoking deal on those converters ;)
These converters were just released about a month ago. They are OBDII (except for CA). You will not have any trouble with these passing emissions as long as your vehicle does not exceed a 5.9L. If it does then I have a big block converter for around $85.
The construction is 409 stainless steel and it uses the same type of ceramic brick that the more expensive converters use (ie MagnaFlow).
id be interested in two 2.5'' thunderbolt catalyic converters and two hooker or magnaflow mufflers in 2.5'' inlet and outlet. do you also sell tubing becase ill be doing it myself. any chance i can get those cable cut-outs that are cast iron?
We do sell tubing (Stainless and Aluminized) although it must be cut into 5 ft sections in order to ship. The cutouts that we have are the ones with the wingnut, you have to crawl under the ride to take them off.
alright ill probably be ordering up a good bit from ya in the near future. i was looking for the cut outs that are cable activated. so i can open them up from inside the cab
As for the tubing, when ordering it off of your site what is the lenght?
do you have any pre-bent 2 1/4 mandrel bends- im lookin to redo my exhaust but don't want to take it too a shop (never what I really want) lemme know
Dan
I don't want to try and steal your business Steve, but muddyblzr I have two brand new (less than 200 miles on them) magnaflow mufflers I am about to cut off of my Blazer. I am going to put a single Flowmaster and hi-flow cat on mine b/c I want it louder. I bought them from Mudfrog on his Performance Curve website. Great site, by the way, and I definitely recommend them! However, I'll sell you my new Magnaflows when I put on the Flowmasters if you want them. They are center in offset out 2.5". I just put them on a month ago, and I only drive my Blazer a couple of miles a day to the gym. I'm in Houston, so let me know if you want them.
Again, Steve, I'm not trying to make you do less business, just trying to re-coup some of my loss on my exhaust system.
No problem I understand, however my name is Scott :wink1:
Also maybe send him a PM next time.
