My 350 sounds like it is hitting on 7 cylinders... (75 GMC)
So, I have deducted that this is a problem that I am not going to fix without a significant amount of time invested in, and since I have another engine... I'm just going to pull this one and put the other one in. (I was intending to do that anyway.) No worth the troubleshooting effort a this point, as I have exhausted all of the reasonable, easy, simple, fast potential issues. I WILL be starting another discussion about my 350/350 swap though!! which commences in 9 days.
Sounds like using a cannon to kill a mosquito, but your choice. One thing that hasn't been mentioned is to check your new plug wires very carefully. I've had issues with wires cracked internally or a poor connection (not fully seated) on plug or distributor, and the symptom always manifests as a miss under load, which typically disappears at idle. Worth a quick examination if you haven't already done so. These days, I don't assume new parts aren't bad out of the box.
